Group: DynoMotion Message: 3469 From: Brad Murry Date: 1/26/2012
Subject: Re: [DynoMotpion] Re: Hanging In dotNet
I will try my best to decipher what is going on.
I did want to make a point to Ray as well as others that most real machines with motion controllers will not survive a single disconnect cycle(Fanuc, Osai, etc…) So it is pretty cool the Kflop can,  at all…
Under normal running circumstances, I do not think there will be an issue but nonetheless I will hunt the ‘bug’ down.
-Brad Murry
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble
Sent: Thursday, January 26, 2012 1:41 PM
Subject: [DynoMotion] Re: Hanging In dotNet
Brad,
I am about to post a dead simple test program that reliably induces this issue about one time out of 3 or so. It will be in my folder in the Files section in a few minutes. If you run, and disconnect/reconnect the board a few times, you'll find after 2-4 disconnects, the app simply hangs. If you interrupt it, it will be on that line with the DLL call I pointed out earlier every time. Note that at this point the board is fine - you can kill and re-start the app without re-connecting the board, and all is well.
BTW - I do NOT have anything else running - just the test app itself.
Hopefully this will enable you and Tom to kill this bug.
Ray L.
> I do occasionally get this as well (hanging on a card call), and I believe
> only when KMotion.exe or KMCNC.exe is running as well. I think someone else
> is getting a token and being selfish with it maybe?
> I have also had instances where the MotionServer will stay in the processes
> and cannot be killed, resulting in the need of a CPU reboot.
> It does appear to work under normal conditions though..
> -Brad
> Sent: Thursday, January 26, 2012 12:36 PM
> It appears to me something, perhaps in the DLL, is getting whacked. When the
> board re-connects, I download and run my init code, then initialize some
> I/Os and Persist Vars. One of the things that gets done is to initialize the
> spindle controls - turning off both relays, and setting the PWM to zero.
> Setting the PWM is done by running my SpindlePWM program on thread 2. The
> new PWM value comes, in part, from values stored in Persist vars 90-92 (for
> SWord, SSO, and actual spindle RPM). The connection hang is coming from a
> call to read the SSO word using WriteLineReadLine passing the String
> "GetPersistDec 92". This var IS initialized before this call is made. On the
> initial connection after my app is started, it works correctly every time.
> After a disconnect/reconnect it goes into
> KM_dotnet_Interop_WriteLineReadLine(_InstanceHandle, _BoardNumber, command,
> ref response); and never returns. If I comment out that one line, then I get
> an completely bogus error when I try to run the SpindlePWM program, telling
> me it couldn't find the file ". That is a single double-quote. The path
> being passed into CompileAndRunCoff is absolutely valid: @"C:\My KFLop C
> Programs\KMotionCNC\KMotionCNCSpindlePWM.c".
> I'm stuck....
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ,
> "himykabibble" <jagboy@> wrote:
> > OK, I thought you had both indicated typical was lower.
> > In trying to pin down the connection hang, I've discovered something
> interesting. There seems to be an interaction between
> KM_Controller.Connected and KM_Controller.CheckIsReady(). As I reported
> yesterday, I can pretty easily get it in a state where Connected is true,
> but CheckIsReady is stuck false, until I disconnect. I've if'd out nearly
> everything in my app except the connection logic, and I frequently find
> Connected does NOT go false when I pull the cable. And, when this happens, I
> also do not get the disconnect dialog from KMotion. I added a
> Console.WriteLine to show me my internal connection state, and the state of
> Connected, and the failure is highly repeatable. But, if I ALSO invoke
> CheckIsReady(), even though I don't USE the value returned, it seems to
> always behave correctly. So it appears Connected does not get properly
> updated under all circumstance UNLESS CheckIsReady() is invoked
> periodically. Does that make any sense? Does it give any clues to what's
> going on here?
> > Also, when the hang occurs, there is a little green arrow next to the line
> indicated below, stating that that line is NEXT to be executed when the CPU
> returns from wherever it currently is. So it appears to be hanging within
> the WriteLineReadLine DLL call.
> > Regards,
> > Ray L.
> Brad Murry <bradodarb@> wrote:
> > > I don't think that sounds too high at all. 2-3 ms may be the theoretical
> > > round trip time, but once you add the non-deterministic Windows timing
> and
> > > the interop I think an average of 15 ms is excellent performance.
> > > -Brad Murry
> > > From: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> [mailto:DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ]
> On
> > > Sent: Thursday, January 26, 2012 10:41 AM
> > > To: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> > > Subject: [DynoMotion] Hanging In dotNet
> > > I've frequently had my app just hang after a re-connect. If I stop the
> > > debugger after the hang, it is ALWAYS at the point indicated by ==>
> below:
> > > public string WriteLineReadLine(string command)
> > > string response = "";
> > > try
> > > MarshalPre(ref response);
> command,
> > > ref response);
> > > ==>MarshalPost(ref response);
> > > What does this mean? I can't step or otherwise continue from this point.
> I
> > > never see this without a disconnect/reconnect. I have to assume it's
> being
> > > influenced by something in my app, since I can't get it to happen with
> my
> > > connection test app. But I have no idea how to pin down the root cause,
> > > since it all works fine as long as I don't go through (usually multiple)
> > > connect/disconnect cycles.
> > > I'm also seeing typical turn-around times for UpdateMainStatus()
> averaging
> > > 15 mSec, as measured using this code:
> > > Stopwatch Watch = new Stopwatch();
> > > Watch.Reset();
> > > Watch.Start();
> > > KMController.UpdateMainStatus();
> > > Watch.Stop();
> > > Console.WriteLine("UpdateStatus: " + Watch.ElapsedMilliseconds + "\n");
> > > The range of numbers I see is from a low of 2-3mSec, to a high of about
> > > 30mSec. Isn't this awfully high? You've both told me it should be
> 1-2mSec,
> > > but I almost never see it that low. Running my minimal connection test
> app,
> > > I see similar, though slightly shorter, times, though there is more
> > > variability there.
> > > Regards,
> > > Ray L.
Group: DynoMotion Message: 3470 From: himykabibble Date: 1/26/2012
Subject: [DynoMotpion] Re: Hanging In dotNet
Brad,
My problem is I'm sometimes seeing the exact same hang WITHOUT a disconnect....
Ray L.
> Osai, etc.) So it is pretty cool the Kflop can, at all.
> but nonetheless I will hunt the 'bug' down.
> -Brad Murry
> Brad,
> Regards,
> Ray L.
> else
> processes
> > -Brad
> On
> the
> the
> (for
> the
> command,
> get
> telling
> > I'm stuck....
> > Regards,
> > Ray L.
> I
> of
> > going on here?
> line
> CPU
> > > Regards,
> > > Ray L.
> theoretical
> > and
> > > > -Brad Murry
> > On
> > below:
> > > > try
> > command,
> > > > ref response);
> point.
> > I
> > being
> > my
> cause,
> multiple)
> > averaging
> > > > Watch.Reset();
> > > > Watch.Start();
> > > > Watch.Stop();
> "\n");
> about
> > 1-2mSec,
> > app,
> > > > variability there.
> > > > Regards,
> > > > Ray L.
